Threads: 9
Hi
I can't start Hybrid AppImage under Linux. I'm using Debian 13 based distro. When launched form terminal the error is:
Hybrid: error while loading shared libraries: libicui18n.so.74: cannot open shared object file: No such file or directory
dpkg -l | grep libicu
ii libicu76:amd64 76.1-4 amd64 International Components for Unicode
Thx
Threads: 70
see:
https://forum.selur.net/thread-4322.html => let me know whether the latest dev AppImage figes the problem.
In case it does I'll look at it tomorrow after work.
Cu elur
Threads: 9
Thx, Hybrid-2026.02.14.1-x86_64.AppImage solved the issue
Threads: 70
Thanks for the feedback.
Threads: 9
Just out of curiosity. Why did You choose AppImage over Flatpak?
Threads: 70
16.02.2026, 11:03
(This post was last modified: 16.02.2026, 11:05 by Selur.)
Simply because I had looked at it before.
Patches for the deploy script are welcome.
